Subject: Re: [EXTERNAL] calcout record processing
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 6 May 2021 18:38:18 +0000
> On May 6, 2021, at 1:05 PM, Mark Rivers via Tech-talk <[email protected]> wrote:
>> But fsControl is also SCAN=Passive in the example. For the FLNK or the INP CP to work, something must trigger fsControl to process.
> Randall's original message said:
>> If I put to fsControl, it sets but nothing happens.
> So my understanding is that he was doing a caput to fsControl, but the FLNK was not processing fsCalc, as it should have.
That would make sense given that DTYP was set; the asynInt32 device support will have disabled the record (leaving PACT as 1) when it didn’t see an address in the INP field. In that state a put to the ai record will not cause it to be processed.
- Andrew
> ________________________________
> From: Hartman, Steven <[email protected]>
> Sent: Thursday, May 6, 2021 12:57 PM
> To: Mark Rivers
> Cc: Arnold, Ned D.; Randall Cayford; [email protected]
> On May 6, 2021, at 1:52 PM, Mark Rivers via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
> He did FLNK from fsControl to fsCalc.  If that FLNK is not actually processing fsCalc than I think it may be because of the DTYP/INP mismatch.
> Steven Hartman
Complexity comes for free, simplicity you have to work for.
Re: [EXTERNAL] calcout record processing Hu, Yong via Tech-talk
calcout record processing Randall Cayford via Tech-talk
Re: calcout record processing Arnold, Ned D. via Tech-talk
RE: calcout record processing Mark Rivers via Tech-talk
Re: [EXTERNAL] calcout record processing Hartman, Steven via Tech-talk
Re: [EXTERNAL] calcout record processing Mark Rivers via Tech-talk
Prev: Re: [EXTERNAL] calcout record processing Randall Cayford via Tech-talk
Next: Re: [EXTERNAL] calcout record processing Hu, Yong via Tech-talk
