Subject: Re: [EXTERNAL] calcout record processing
To: "Johnson, Andrew N." <[email protected]>, "Rivers, Mark L." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 6 May 2021 19:03:31 +0000
I just did a quick test. Randall's problem is repeatable. If a record (e.g. testAsyn) has DTYP "asynInt32" but no field(INP, "@..."), its FLNKed record will not be processed after a put to testAsyn.  However, the value of  testAsyn is changed although its alarm severity is INVALID.
[yhu@sps-diaglabs-dev-ibm example]$ caput testAsyn 1
Old : testAsyn                       0
New : testAsyn                       1
[yhu@sps-diaglabs-dev-ibm example]$ caget -a testAsyn
testAsyn                       <undefined> 1 UDF INVALID
And I get a waring message related to devAsynInt32 after iocInit. Probably Randall did not pay enough attention to that kind of warning.
Starting iocInit
## EPICS R7.0.5
## Rev. R7.0.5-dirty
testAsyn devAsynInt32::initCommon  invalid INST_IO Must be asynMask(<port> <addr> <mask> <timeout>)userParams
BTW, "PP" is not needed in the field FLNK. This seems more straightforward to me: field(FLNK, "$(P):fsCalc")
Cheers,
-- Yong
On 5/6/21, 2:38 PM, "Tech-talk on behalf of Johnson, Andrew N. via Tech-talk" <[email protected] on behalf of [email protected]> wrote:
    > On May 6, 2021, at 1:05 PM, Mark Rivers via Tech-talk <[email protected]> wrote:
    >> But fsControl is also SCAN=Passive in the example. For the FLNK or the INP CP to work, something must trigger fsControl to process.
    > Randall's original message said:
    >> If I put to fsControl, it sets but nothing happens.
    > So my understanding is that he was doing a caput to fsControl, but the FLNK was not processing fsCalc, as it should have.
    That would make sense given that DTYP was set; the asynInt32 device support will have disabled the record (leaving PACT as 1) when it didn’t see an address in the INP field. In that state a put to the ai record will not cause it to be processed.
    - Andrew
    > ________________________________
    > From: Hartman, Steven <[email protected]>
    > Sent: Thursday, May 6, 2021 12:57 PM
    > To: Mark Rivers
    > Cc: Arnold, Ned D.; Randall Cayford; [email protected]
    > On May 6, 2021, at 1:52 PM, Mark Rivers via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
    > He did FLNK from fsControl to fsCalc.  If that FLNK is not actually processing fsCalc than I think it may be because of the DTYP/INP mismatch.
    > Steven Hartman
    Complexity comes for free, simplicity you have to work for.
calcout record processing Randall Cayford via Tech-talk
Re: calcout record processing Arnold, Ned D. via Tech-talk
RE: calcout record processing Mark Rivers via Tech-talk
Re: [EXTERNAL] calcout record processing Hartman, Steven via Tech-talk
Re: [EXTERNAL] calcout record processing Mark Rivers via Tech-talk
Re: [EXTERNAL] calcout record processing Johnson, Andrew N. via Tech-talk
Prev: Re: [EXTERNAL] calcout record processing Johnson, Andrew N. via Tech-talk
Next: Building areaDetector on Windows with MSYS2 and MINGW64 Smith, William via Tech-talk
