1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: record with constant input link
From: Gerrit Kühn via Tech-talk <tech-talk at aps.anl.gov>
To: Gerrit Kühn via Tech-talk <tech-talk at aps.anl.gov>
Date: Tue, 7 Nov 2023 11:10:22 +0100
Am Mon, 6 Nov 2023 11:53:50 +0100
schrieb Gerrit Kühn via Tech-talk <tech-talk at aps.anl.gov>:
> > Can you set up your low level asyn drivers to connect to the device
> > *after* iocInit has been run? Switching them to autoconnect at the end
> > of the st.cmd?
> Maybe, I probably just fail to see how to do that. I included
> "noAutoConnect" in my drvAsynIPPortConfigure:
> drvAsynIPPortConfigure("TF1", "localhost:4000", noAutoConnect)
> Then after iocInit (last command of st.cmd) I added
> asynAutoConnect("TF1", "localhost:4000", yes)
> However, this results in lots of error messages tarting with
> Cannot find a bus named 'TF1'
Meanwhile I found that the latter should probably be something like
asynAutoConnect("TF1", 0, 1), but I still get the "Cannot find bus" error
when using noAutoConnect for IPPortConfigure. Any hint how to set this up
properly would be greatly appreciated. :)
cu
  Gerrit
Attachment: smime.p7s
Description: S/MIME cryptographic signature
record with constant input link Gerrit Kühn via Tech-talk
Re: record with constant input link Simon Rose via Tech-talk
Re: record with constant input link Gerrit Kühn via Tech-talk
Re: record with constant input link Rolf Keitel via Tech-talk
Re: record with constant input link Ralph Lange via Tech-talk
Prev: Re: A Modbus problem relating to byte order and endian Maren Purves via Tech-talk
Next: Re: Sequencer interpretation of PV names with {,} characters Érico Nogueira Rolim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: record with constant input link Gerrit Kühn via Tech-talk
Next: Sequencer interpretation of PV names with {,} characters Ivashkevych, Oksana via Tech-talk
ANJ, 07 Nov 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
