1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: "duty cycle" records
From: Gerrit Kühn via Tech-talk <[email protected]>
To: Rolf Keitel via Tech-talk <[email protected]>
Date: Thu, 23 Nov 2023 08:34:45 +0100
Am Wed, 22 Nov 2023 11:06:46 -0800
schrieb Rolf Keitel via Tech-talk <[email protected]>:
Hello Rolf,
This works, thanks.
However, now I wonder how to properly change these settings while running.
When I write a different value (using caput) into .INPA, this doesn't get
picked up by .A. I can write to .A directly, but I had actually expected
this to be read from .INPA on each cycle. Somehow it feels wrong to have .A
and .INPA not in sync.
cu
  Gerrit
> Hi Gerrit,
> You cannot point a link field at another link field.
> If you set in the second record
> field (INPA, "$(CHAN)_DUTY_CYC.A")
> you should get what you want. - rolf -
> On 2023-11-22 8:07 a.m., Gerrit Kühn via Tech-talk wrote:
> > Am Wed, 22 Nov 2023 16:23:29 +0100
> > schrieb Gerrit Kühn via Tech-talk<[email protected]>:
> >>> You need to put PP at the end of your OUT link to force the second
> >>> record to process.
> >> Yes, that was the mssing bit. Thanks to both of you for pointing this
> >> out to me.
> > Last question for today (hopefully). I have these records now:
> > record (calcout, "$(CHAN)_DUTY_CYC") {
> >    field (DESC, "duty cycled output")
> >    field (VAL,  "10") # 1st cycle time
> >    field (INPA, "10") # cycle time
> >    field (CALC, "VAL-1")
> >    field (OUT, "$(CHAN)_DUTY_RESET PP")
> >    field (OOPT, "Transition To Zero")
> >    field (SCAN, "1 second")
> > record (calcout, "$(CHAN)_DUTY_RESET") {
> >    field (DESC, "reset cycle counter")
> >    field (VAL, "11")
> >    field (INPA, "$(CHAN)_DUTY_CYC.INPA")
> >    field (CALC, "A")
> >    field (OUT, "$(CHAN)_DUTY_CYC")
> >    field (SCAN, "Passive")
> > The second record gets processed when the counter in the first record
> > reaches zero. However, it only resets the counter as desired when the
> > INPA field in the second record is defined constant (i.e., INPA, "10"
> > directly in the second record).
> > My original idea as written above was to get the INPA field of the
> > second record from the INPA field of the first record. However, this
> > does not work. camonitor reports this as "LINK INVALID" although I can
> > use caget on the reported link just fine (and get the correct value).
> > Again, this feels like I'm missing a simple thing...
> > cu
> >    Gerrit
Attachment: smime.p7s
Description: S/MIME cryptographic signature
RE: "duty cycle" records Žiga Oven via Tech-talk
"duty cycle" records Gerrit Kühn via Tech-talk
Re: "duty cycle" records Ralph Lange via Tech-talk
Re: "duty cycle" records Gerrit Kühn via Tech-talk
Re: "duty cycle" records Mark Rivers via Tech-talk
Re: "duty cycle" records Rolf Keitel via Tech-talk
Prev: Re: "duty cycle" records Rolf Keitel via Tech-talk
Next: RE: "duty cycle" records Žiga Oven via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
