Hi Gerrit,
Why not have an AO record that holds the timeout duration value and pushes it to the calc record only on reset?
record(ao, "$(CHAN)_DUTY_CYC_LEN") {
field(VAL, "10")
field(OUT, "$(CHAN)_DUTY_CYC.VAL")
field(PINI, "YES")
record (calcout, "$(CHAN)_DUTY_CYC") {
field (DESC, "duty cycle")
field (CALC, "VAL-1")
field (OUT, "$(CHAN)_DUTY_CYC_LEN.PROC")
field (OOPT, "Transition To Zero")
field (SCAN, "1 second")
The only drawback of the approach above, is that while the countdown will have 10 values [1..10] the DUTY_CYC.VAL will never be reported as 0 on the camonitor.
Best regards,
Žiga
> -----Original Message-----
> From: Tech-talk <[email protected]> On Behalf Of Gerrit Kühn
> via Tech-talk
> Sent: Thursday, November 23, 2023 8:35 AM
> To: Rolf Keitel via Tech-talk <[email protected]>
> Subject: Re: "duty cycle" records
> Am Wed, 22 Nov 2023 11:06:46 -0800
> schrieb Rolf Keitel via Tech-talk <[email protected]>:
> Hello Rolf,
> This works, thanks.
> However, now I wonder how to properly change these settings while running.
> When I write a different value (using caput) into .INPA, this doesn't get
> picked up by .A. I can write to .A directly, but I had actually expected
> this to be read from .INPA on each cycle. Somehow it feels wrong to have .A
> and .INPA not in sync.
> cu
> Gerrit
> > Hi Gerrit,
> > You cannot point a link field at another link field.
> > If you set in the second record
> > field (INPA, "$(CHAN)_DUTY_CYC.A")
> > you should get what you want. - rolf -
> > On 2023-11-22 8:07 a.m., Gerrit Kühn via Tech-talk wrote:
> > > Am Wed, 22 Nov 2023 16:23:29 +0100
> > > schrieb Gerrit Kühn via Tech-talk<[email protected]>:
> > >>> You need to put PP at the end of your OUT link to force the second
> > >>> record to process.
> > >> Yes, that was the mssing bit. Thanks to both of you for pointing this
> > >> out to me.
> > > Last question for today (hopefully). I have these records now:
> > > field (DESC, "duty cycled output")
> > > field (VAL, "10") # 1st cycle time
> > > field (INPA, "10") # cycle time
> > > field (OUT, "$(CHAN)_DUTY_RESET PP")
> > > record (calcout, "$(CHAN)_DUTY_RESET") {
> > > field (DESC, "reset cycle counter")
> > > field (VAL, "11")
> > > field (INPA, "$(CHAN)_DUTY_CYC.INPA")
> > > field (CALC, "A")
> > > field (OUT, "$(CHAN)_DUTY_CYC")
> > > field (SCAN, "Passive")
> > > The second record gets processed when the counter in the first record
> > > reaches zero. However, it only resets the counter as desired when the
> > > INPA field in the second record is defined constant (i.e., INPA, "10"
> > > directly in the second record).
> > > My original idea as written above was to get the INPA field of the
> > > second record from the INPA field of the first record. However, this
> > > does not work. camonitor reports this as "LINK INVALID" although I can
> > > use caget on the reported link just fine (and get the correct value).
> > > Again, this feels like I'm missing a simple thing...
> > > cu
> > > Gerrit
- Re: "duty cycle" records Gerrit Kühn via Tech-talk
- "duty cycle" records Gerrit Kühn via Tech-talk
- Re: "duty cycle" records Ralph Lange via Tech-talk
- Re: "duty cycle" records Mark Rivers via Tech-talk
- Re: "duty cycle" records Rolf Keitel via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
