Am Thu, 23 Nov 2023 08:38:59 +0000
schrieb Žiga Oven <[email protected]>:
Hello Žiga,
I had tried that first, but couldn't get the "only on reset" part working:
record (ao, "$(CHAN)_DUTY_CYC_TIM1") {
field (DESC, "duty cycle time 1")
field (VAL, "10")
field (OUT, "$(CHAN)_DUTY_CYC1")
field (PINI, "YES")
field (SCAN, "Passive")
record (ao, "$(CHAN)_DUTY_CYC_TIM2") {
field (DESC, "duty cycle time 2")
field (VAL, "20")
field (OUT, "$(CHAN)_DUTY_CYC2")
record (calcout, "$(CHAN)_DUTY_CYC1") {
field (DESC, "duty cycled counter 1")
field (CALC, "VAL-1")
field (OUT, "$(CHAN)_DUTY_RESET2 PP")
field (OOPT, "Transition To Zero")
field (SCAN, "1 second")
record (calcout, "$(CHAN)_DUTY_CYC2") {
field (DESC, "duty cycled output 2")
field (OUT, "$(CHAN)_DUTY_RESET1 PP")
record (calcout, "$(CHAN)_DUTY_RESET1") {
field (DESC, "reset cycle counter 1")
field (INPA, "$(CHAN)_DUTY_CYC_TIM1")
field (CALC, "A")
record (calcout, "$(CHAN)_DUTY_RESET2") {
field (DESC, "reset cycle counter 2")
field (INPA, "$(CHAN)_DUTY_CYC_TIM2")
field (CALC, "A")
This is pretty much what you proposed as far as I understand? This does
what I need, but you have to take care when changing TIM1 or TIM2 as it
gets at once pushed out to the respective CYC record. This is fine for the
one being "active" (running on positive numbers) but it will screw up
everything if you change the one running on negative numbers.
So my idea was that having the timing values in the INP/A fields of the CYC
records lets you change them independently of the running cycles, they
will only be picked up when the reset record is processed (the action
records are still dummies that just count how often they are called):
field (VAL, "10") # 1st cycle time
field (INPA, "10") # cycle time 1
field (INPA, "20") # cycle time 2
field (INPA, "$(CHAN)_DUTY_CYC1.A")
field (CALC, "A")
field (FLNK, "$(CHAN)_DUTY_ACT1")
field (INPA, "$(CHAN)_DUTY_CYC2.A")
field (CALC, "A")
field (FLNK, "$(CHAN)_DUTY_ACT2")
record (calcout, "$(CHAN)_DUTY_ACT1") {
field (DESC, "duty cycle action 1")
field (CALC, "VAL+1")
record (calcout, "$(CHAN)_DUTY_ACT2") {
field (DESC, "duty cycle action 2")
> Why not have an AO record that holds the timeout duration value and
> pushes it to the calc record only on reset?
> record(ao, "$(CHAN)_DUTY_CYC_LEN") {
> field(VAL, "10")
> field(OUT, "$(CHAN)_DUTY_CYC.VAL")
> field(PINI, "YES")
> record (calcout, "$(CHAN)_DUTY_CYC") {
> field (DESC, "duty cycle")
> field (OUT, "$(CHAN)_DUTY_CYC_LEN.PROC")
> The only drawback of the approach above, is that while the countdown
> will have 10 values [1..10] the DUTY_CYC.VAL will never be reported as 0
> on the camonitor.
> Best regards,
> Žiga
> > -----Original Message-----
> > From: Tech-talk <[email protected]> On Behalf Of Gerrit
> > Kühn via Tech-talk
> > Sent: Thursday, November 23, 2023 8:35 AM
> > To: Rolf Keitel via Tech-talk <[email protected]>
> > Subject: Re: "duty cycle" records
> > Am Wed, 22 Nov 2023 11:06:46 -0800
> > schrieb Rolf Keitel via Tech-talk <[email protected]>:
> > Hello Rolf,
> > This works, thanks.
> > However, now I wonder how to properly change these settings while
> > running. When I write a different value (using caput) into .INPA, this
> > doesn't get picked up by .A. I can write to .A directly, but I had
> > actually expected this to be read from .INPA on each cycle. Somehow it
> > feels wrong to have .A and .INPA not in sync.
> > cu
> > Gerrit
> > > Hi Gerrit,
> > > You cannot point a link field at another link field.
> > > If you set in the second record
> > > field (INPA, "$(CHAN)_DUTY_CYC.A")
> > > you should get what you want. - rolf -
> > > On 2023-11-22 8:07 a.m., Gerrit Kühn via Tech-talk wrote:
> > > > Am Wed, 22 Nov 2023 16:23:29 +0100
> > > > schrieb Gerrit Kühn via Tech-talk<[email protected]>:
> > > >>> You need to put PP at the end of your OUT link to force the
> > > >>> second record to process.
> > > >> Yes, that was the mssing bit. Thanks to both of you for pointing
> > > >> this out to me.
> > > > Last question for today (hopefully). I have these records now:
> > > > field (DESC, "duty cycled output")
> > > > field (OUT, "$(CHAN)_DUTY_RESET PP")
> > > > record (calcout, "$(CHAN)_DUTY_RESET") {
> > > > field (DESC, "reset cycle counter")
> > > > field (VAL, "11")
> > > > field (INPA, "$(CHAN)_DUTY_CYC.INPA")
> > > > field (CALC, "A")
> > > > field (OUT, "$(CHAN)_DUTY_CYC")
> > > > The second record gets processed when the counter in the first
> > > > record reaches zero. However, it only resets the counter as
> > > > desired when the INPA field in the second record is defined
> > > > constant (i.e., INPA, "10" directly in the second record).
> > > > My original idea as written above was to get the INPA field of the
> > > > second record from the INPA field of the first record. However,
> > > > this does not work. camonitor reports this as "LINK INVALID"
> > > > although I can use caget on the reported link just fine (and get
> > > > the correct value). Again, this feels like I'm missing a simple
> > > > thing...
> > > > cu
> > > > Gerrit
smime.p7s
Description: S/MIME cryptographic signature
- RE: "duty cycle" records Žiga Oven via Tech-talk
- "duty cycle" records Gerrit Kühn via Tech-talk
- Re: "duty cycle" records Ralph Lange via Tech-talk
- Re: "duty cycle" records Gerrit Kühn via Tech-talk
- Re: "duty cycle" records Mark Rivers via Tech-talk
- Re: "duty cycle" records Rolf Keitel via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
