1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Re: Help in debugging ACF connection issue
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: Érico Nogueira Rolim <erico.rolim at lnls.br>
Cc: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Mon, 13 Apr 2026 08:20:49 -0700
On 4/13/26 7:58 AM, Érico Nogueira Rolim via Tech-talk wrote:
... does PVXS support dynamic discovery of network interfaces?
In part, for some configurations.  Enough for my laptop to roam and have pvxmonitor reconnect when I get home.  Interface (re)discovery is there[1].  However, at present auto-address list expansion[2] only happens once at server or client creation.  So the list of UDP broadcast addresses is the practical limitation.  Binding to specific interface addresses is of course also a problem (IP_FREEBIND is not portable).
[1] the IfaceMap API is backed by a worker thread which periodically polls interface info.
https ://github.com/epics-base/pvxs/blob/1d481d5be1db1e1bcc934c82a8bcec162c3ac31f/src/evhelper.h#L306
[2] expandAddrList() https ://github.com/epics-base/pvxs/blob/1d481d5be1db1e1bcc934c82a8bcec162c3ac31f/src/config.cpp#L284
Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
Re: Help in debugging ACF connection issue Michael Davidsaver via Tech-talk
Re: Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
Re: Help in debugging ACF connection issue Hu, Yong via Tech-talk
RE: Help in debugging ACF connection issue Stephen Dann - STFC UKRI via Tech-talk
Prev: Re: Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
Next: Re: RTEMS/MVME2100 OMS58 card does not exist! error Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Next: Collaboration on use of EPICS for engine rig control (Single-Cylinder Engine Test Cell at Chalmers University Of Technology in Gothenburg) Djordje Purkovic via Tech-talk
ANJ, 13 Apr 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
